83 Tercel 4wd parts
margotK
My tercel:: 1986 Tercel 4wd 1.5L
83 Tercel 4wd parts
Post by margotK »
Hey guys, so unfortunately the 1983 Tercel SR5 that I am parting out will need to be gone by July 30th. I have taken the majority of things that I needed for my car, but almost everything else is still there. The body has surface rust all around but the interior has everything short of the inclinometer. I still have the transmission and anything mechanical except for the carburetor (swapped mine while I rebuild my original). If there is anything that you guys need from this generation please let me know. I will post pictures of the car later.
Thanks!
Eli
boisesr5
My tercel:: 1984
Re: 83 Tercel 4wd parts
Post by boisesr5 »
I need a rocker arm shaft and the fist two supports. Do you have those?
Jim
helipilot77
My tercel:: 1984 SR5 wagon
Post by helipilot77 »
I know 4wdEconoBox was looking for a drivers side window regulator. I had one I was trying to repair for him, but I think it is a lost cause.
. / TOYOTA
./_| |/|/ |]
BaileySims
Post by BaileySims »
I am in desperate need of the turn signal stalk. I broke mine today. :(
And the steering column cover if you've got that too. In a blind rage caused by the destruction of the turn signal stalk, I ripped off the cover because I had no screwdriver.
WAGON MAFIA.
Blood, sweat and beers.
BaileySims
Let's see if super glue works for now.
WAGON MAFIA.
toledo
My tercel:: 1983 SR5
Post by toledo »
Happen to have a fuse box and or wiring harness?
margotK
Post by margotK »
Hey guys, sorry I haven't replied, I have been in and out of town quite a bit these past few days. to answer your questions:
Helipilot77, I have the driver side window regulator, but it's fairly stiff. I cleaned the one on mine and lubed it up and it seemed to have worked pretty well these past few months.
Baileysims, I have the turn signal stalk, as well as the column cover if you would like them. Im not sure if you are particular on the color of the cover, but it is the grey vinyl. I can send a picture to you. I'll pull them just in case you still need them if the superglue didn't hold.
Boisesr5, not to sound like the newbie that I am, but unfortunately my knowledge on checking the condition of those is pretty minimal (as in none). Is there anyway that you could maybe give me some advice on it? I'd like to help you out.
Thanks guys,
Eli
margotK
Post by margotK »
Also, toledo, which fuse box or harness are you looking for in particular?
4wdEconoBox
My tercel:: 1985 Toyota Tercel SR5 4WD
Post by 4wdEconoBox »
I'd definitely be interested in the drivers side window regulator!
margotK
Post by margotK »
I'll message you a picture of it 4wdEconoBox.
The Professor
Post by The Professor »
Do you have adjustable intermittent wipers or cruise control?
1975 Subaru SuperStar wagon
1987 Subaru RX 3-door
1987 Subaru RX Type-RA 3-door
1987 Toyota Tercel SR5 wagon
1999 Subaru Forester S
2002 Subaru WRX sedan
margotK
Post by margotK »
The Professor, unfortunately no. I'm not sure that they put intermittent controls in 83's. I could be wrong on that but I have never seen it myself.
no tercel had adjustable intermittent wipers, I am pretty sure they all have a non-adjustable intermittent position.
there is a thread in the archives to adapt an 84-87 SR-5 Forerunner adjustable intermittent stalk to the Tercel, connector is compatible so it only takes a few tweaks of the column cover/trim to get it to fit.
Petros wrote: Mon Jul 17, 2017 3:56 pm no tercel had adjustable intermittent wipers, I am pretty sure they all have a non-adjustable intermittent position.
The '86 Dealer Brochure I have states that variable intermittent wipers came with the Cruise Control Package ...
gnarnold
My tercel:: 1983 SR5 4x4 with a tummy tuck and a nose job and now a pace maker!
Post by gnarnold »
Have you got rid of that that steering column cover yet cuz I sure could use it cuz I have none have no column whatsoever and I'm getting pulled over because they think I'm stolen the car it's ridiculous sure could use that thing man oh boy
I used to laugh at the man with a pinto :lol: , until I became a humble servicer of a tercel :|
