would 207/70/14's fit???
Carguylen
Post by Carguylen »
I can get ahold of a set of 205/70/14's in excellent shape free. I want to get a set of 14 inch rims, and if I did, would these be to big?
Aussie_3ASCV
Post by Aussie_3ASCV »
yeah my 15's fit with a bit of rubbing in reverse only on full lock. not much at all. 14's would be perfect. i keep getting speeding fines though cause my speedos way out
84 SR5, 4A, 75W Globes, CB Radio, Twin 13" Subs with Twin 750W Amps, Neons, 15" Enkei Rims Fitted With 215 65-15 Tyres, 200000Km on clock, GPS, Hood Scoop and plenty more to come. I love my terc
Aussie_3ASCV wrote: i keep getting speeding fines though cause my speedos way out
I use small triangles of colored vinyl tape stuck on the speedo plastic to indicate the usual in town and highway speed limits when I have bigger tires on a car. Around here...25...35...55 mph.
Cheaper than tickets.
Typrus
Post by Typrus »
205/70R14's are a significant boost in diameter... Over bumps you may experience serious fender rubbing. In fact, for the 205/75R14's, a minimum 2 inch lift is recommended for safety.
Mac
Post by Mac »
if your speedo is out, move the needle a little bit down, so it sits before 0.
it won't be totally acurate, but it will give you a better idea of how fast your going.
simon84
Post by simon84 »
I run 205/70/14 tires and have put in about 1.5 inches of lift. I get slight rubbing at full turning lock and no rubbing on bumps. I used to get rubbing on bumps before the lift, but rubber donut spring boosters helped a bit. My speedo is exactly 10% out. So when my speedo says 100kmh I am actually going 110.
I checked it with a GPS.
I like the ride on 14's for sure. Probably help with mileage as well.
20vtercel
Post by 20vtercel »
Carguylen wrote: I can get ahold of a set of 205/70/14's in excellent shape free. I want to get a set of 14 inch rims, and if I did, would these be to big?
I ran 205/50/14's lowered 2" without any issues. My sidewals are shorter tho.
