Road Noise
Jonymoto
Road Noise
Post by Jonymoto »
"Love those Tercell 4x4 wagons but they sure suffer from road noise" says Xirdneh.
I was driving my wife's Rav4 last weekend as I needed to use the trailer. Apart from the extra 58kw of power, I noticed that it wasn't as noisy as the Tercel in terms of road noise, especially from the back. I did the rear wheel bearings recently, so it's not them. And the noise is no worse than when it was a newer car, just relative to the RAV4 it is and the RAV itself is not very quiet compared to a Sedan. So it got me thinking about improving that situation. The tyres on the Tercel are almost brand new Goodyear.
Has anyone fitted sound deadener in their Tercels, like Dynamat? If so, did it make any difference?
Re: Road Noise
i haven't tried improving sound deadening and can't contribute anything in that way, but did want to mention that i have noticed that all entry level cars seem to be really loud inside, and that noise improves as the cars get 'nicer.' for example, my corolla is a lot quieter than my tercels were, but a camry is even quieter. i guess sound deadening is one of the things manufacturers cut corners on when making cheap entry level cars. my wife's 92 civic is the worst though, far more so than any tercel, even one with bad bearings. i've driven a few civics of the same generation and they're all so loud that the first time i drove one, i thought all the bearings must be shot. after a few more similar experiences, i figured that's just the way they are.
larry mcgrath
Re: Road Noise
Post by larry mcgrath »
I instaled insulation that they wrap A/C house ducking with --glued in place in floor boards and doors, if you look in my post Larrys tercel gets a v20 B/T you'll see where it was installed . Works great and realy cut the noise level by 60- 70% and it is cheap Larry its on page 8 larry :D
rer233
My tercel:: Multiple
Re: Road Noise
Post by rer233 »
Pulled the seats and carpets (front, rear and cargo area) out of both my '87 wagons and cleaned them with floor cleaner, a scrub brush, and a hose (they were FILTHY.) The factory jute insulation backing kinda took a beating, so I got some 1/2" foam carpet underlayment from Home Depot and spray-glued it to the bottom of all the mats. Made a big difference in the noise level, and seems to be warmer in the winter.
Let us know how it works out!
Re: Road Noise
here's the link to the post larry mentioned:
viewtopic.php?f=6&t=7576&start=105#p68994
Re: Road Noise
the more sound deadening insulation you put in the car, the more weight you add to it. We once had a Buick that was given to us, I did not care for the car much so my wife drove it. it was very quiet inside. eventually it developed a leak I could not track down, tried many times and used various methods, even a so called "pro" that I paid to find the leak could not locate it. In the process I removed the seats and carpet so they would not get moldy, the floor would fill with water like a tub, so I removed the rubber drain plug and it all drained out. We drove it one winter like that, and it was as noisy as a '59 pick up truck. The moulded insulation layers under the carpet was over an inch thick of very dense foam material. they must have weight over a hundred pounds (even when dry).
It is high density layers that the stops the noise, very light weight insulation will stop heat loss, but not do much to stop noise. It takes mass. Anything you add under the carpets would help, but the more dense the better. Also, make or add a boot to the shift lever, and make sure your door seals, the seals on the fire wall for the wire bundles are all good (or use silicone sealer on them). These all let noise in.
I have been meaning to try some of that noise deadening insulation on my Tercel next time I have the carpets out to clean them. the best ones have a layer of metal in them.
Jonymoto
Re: Road Noise
Post by Jonymoto »
Thanks guys. I'm very encouraged by what Larry said. So I've got myself a project. Still got to change the rear diff to 4.1 ratio and get the windows tinted as well.
I will keep you updated and include photos.
Thanks for putting up Larry's link DLB (PS - I didn't know Vancouver was also an island until I looked up your location on a map a few weeks ago. I knew about Vancouver city though).
This is a fantastic site. Compliments to all of you.
splatterdog
Re: Road Noise
Post by splatterdog »
If you have rust holes, that's an entry point for noise too. Dynamat(or equivalent) helps a lot for sound deadening. I think there is a roofing product that is similar at much less cost. Might have more odor though.
Drove a BMW 7 series once. Quietest car I ever drove. Doesn't make me want one though. I have a 5 door minimum.
195/70R14 tires will take away about 200 rpms at cruising speed. That helps too.
Been wanting to fab the OE air cleaner to the weber. Open element air cleaners are always noisy.
Re: Road Noise
Post by irowiki »
I can definitely vouch for the Camry being very nice when it comes to road noise!
