Zach's 1985 4WD Tercel Wagon
Re: Zach's 1985 4WD Tercel Wagon
I've always just wire wheeled nuts and bolts when doing machinery restoration. Unless you can get OE replacements, new ones rarely match close enough and really stick out as different looking.
1985 Tercel 5dr Hatchback
2003 Chevy Suburban
2014 Ford Flex
2003 Chevy Suburban
2014 Ford Flex
- lannvouivre
THE EAGLE HAS LANDED and looks as American as it can when it's short 4 cylinders and a V-shape.
That PCV filter idea, while clever, is also EXTREMELY messy, and I speak from experience.
- lannvouivre
That's the breather! I'll have to figure something out for it.
I finished plugging the ports on the exhaust manifold and painted it a flat black. I also replaced the heater core without even killing anyone when I realized that I would need to pull the steering wheel to cleanly pull the dash (I instead broke all the steering column support bolts and nuts loose and lowered it that way, then turned the steering wheel to push the caught part out...it was messy and unprofessional).
Also found out my replacement bolts for the manifolds are too long. Will have to drop by AIP tomorrow, I guess.
- lannvouivre
Oh, and I found that the aftermarket speaker wires were just taped. Also found a thickly insulated single-filament wire that had copper mesh shielding. Goes from the driver's side to the passenger's side and disappears between some HVAC enclosures. That was taped with painter's tape.
One of the heater core enclosure's doors has a broken control cable as well.
- lannvouivre
Made new battery cables and prepped a wiring harness. I also anointed it with blood because I am just so good at using knives.
Great line, and one to which we can all attest.lannvouivre wrote: I also anointed it with blood because I am just so good at using knives.]
If you cannot attest - you are lying...
I think all of our cars have a little, and sometimes a lot, of blood, sweat and tears in them.
- lannvouivre
The new terminals are here! UNF! BEAUTIFUL! *immediately covers them with opaque terminal covers*
- lannvouivre
Replaced the brake booster hose between the check valve and intake vacuum port.
Got new fuel injection hoses.
Got new heater hoses and realized I don't remember the routing.
Still need to clean up the EGR block-off and fuel pump block-off plates and paint them.
Need to install battery cables.
Need to check battery.
Need to install starter.
Need to install mechanical fuel pump.
Need to replace fuel filter.
Need to install heater hoses.
Need to fill cooling system.
Need to install alternator.
Need to tighten all hose clamps.
Need to install axle seals and axles.
Need to fill transmission.
Need to test start engine.
Need to install dash if heater core replacement does not leak.
Need to take care of front speaker wiring.
Need to check up on tail light wires.
Need to make sure car will pass inspection.
Need new front shock inserts that fit.
- lannvouivre
Heater hoses are on, battery cables are on, starter is on, most of the clamps are tightened.
Tomorrow, I will seat axle seals, install axles, fill the transmission, install the alternator, install a couple more horse clamps, install the fuel pump, paint and install the EGR plate, fill the cooling system, and start 'r up.
you sure those go on a Tercel, or were you thinking of something else?lannvouivre wrote:..install a couple more horse clamps,...
- BaileySims
Petros wrote:you sure those go on a Tercel, or were you thinking of something else?lannvouivre wrote:..install a couple more horse clamps,...
WAGON MAFIA.
Blood, sweat and beers.
- lannvouivre
My typing is second to none, don't judge me! Bailey understand me, at least.
Got everything all hooked up. Identified the mystery dash wire as the antenna wire and ripped that out. Local radio stations are absolute trash nowadays.
Still need to fill the cooling system and transmission, but wanted to make sure the engine would crank. I need to take care of the wire from transmission to chassis near the starter.
Also need to know where the smaller wire that's on the starter-end of the battery cable is supposed to go, because I don't remember and it obviously is not a ground since it's part of the positive cable.
not judging, just wanted a clarification. Not many horses on a Tercel, lost of hoses however.lannvouivre wrote:My typing is second to none, don't judge me! Bailey understand me, at least.
BTW, the "extra" wire on the starter bundle could be either the solonid wire (it would only be energized when the key is turned to the "start" position), or the heavy wire that goes to the fuse box to power the accessory panel.
