The answer to your question is simple.....russkiypenguin wrote: I'm actually a bit confused by the sudden obsession over the need for frame rigidification. I watch quite a bit of shows on TV about people SERIOUSLY upgrading their HP and they never have to boost their frames. I mean if this is just a "do it because you feel like it" thing then I'm fine with that, but I don't really understand why people are trying to justify it. Bent frames come from collisions or REALLY REALLY powerful engines like a 500HP big block. Not an un-turboed 4cylinder swap out.
I hope this isn't offensive to anyone. I'm not trying to offend anyone, but I don't actually understand why a few people are so interested in this.
What is the difference between what you see on t.v. and real life??? (and this goes for everything) You sometimes never know the whole story!!
Actually, you'd be suprised to know that most cars that get built on tv are re-worked to incorporate frame strengthening.
Also, what you see on tv is older cars with "<span style='color:red'>F U L L F R A M E S</span>" not unit bodies where there is a 1/4 frame in the front and 1/4 frame in the back. Not to mention a car in the 60's was made with HP in mind and cars nowadays have light and economical and $$$ making built into them.
Simply put...and any car guy should know this...you cannot put more than stock hp into unit body frames and expect that nothing is going to happen.
Take my camaro for example...It is a unit body. Stock, they have a problem with stress cracks starting right behind the b pillar at the roof. Guess what?? 190hp into a unit body is not a good thing. Same goes for mustangs and other cars. It is something that cannot be ignored and if you chance it...it's your problem!!!!
Oh, and i mean no offence...but there are some shows for good information and overhaulin', two guys garage (shadetree mechanic), or HotRod TV etc...are not by any means that!!! They are just about bolt-ons and slapping stuff together. It gives the viewer the basics but doesn't really go into the support for what they've done. One of the biggest laughes i get out of thoes shows is the pronunciation of the products. You can tell those guys are just hosts and not much more than that!!!
I like the overhaulin' show...they do the baer break upgrade, but what they don't tell you is that they had to upgrade the break bootser to power them!!! and so on and so forth.
IOW, you can't believe everything you see on TV!!!
Oh and another thing. 1,000,000 hp in our cars will not hurt anything...90ft lbs of torque will!!!
Remember - Torque is the power of the engine to get a mass to move. HP is the speed of which it reaches your peak power!!!
I put a k&n cone on the end of the afm and stuck it in the fender. FWI!!!What did you use as an air cleaner and filter box?
I have no use for crap equiment like filter boxes. pffft
It twisted cuz of the torque. Why? our frames are weak.What happened to my frame?? Why?
Trust me...you have 80hp 79ft lbs of torque. You more than double your hp and double the torque. Say the braces were only designed for the lower hp. You now need braces that are 4 times the strength of originals to handle double the torque.
