Tercel Part blowout! EVERYTHING must go!
I am clearing out almost ALL of my Tercel parts including my Last Tercel. Pricing will depend on your offer vs what it sells for new vs how rare it is plus shipping. I will go back in and edit in suggested prices later. Will add more things as we find them. Doesn't count the boxes of crap I have that will eventually go in the garbage like old heads etc.
The more you buy, the more you save. I don't want to throw this stuff away! If you buy any big items I might end up stuffing little things in the box.
ALL PROCEEDS GO TOWARDS THE SERVER FUND!
I can accept paypal, google wallet (if that is still a thing), cash or check. Unless I know you, I will only ship after I am paid! If you are in driving distance of Farmington, NM I have a bunch of stuff you can just have! If you don't see it listed just ask I might have it. Keep in kind this is only like 25% of what I've actually collected...
Starting with the new or mostly new stuff:
prices are each:
DNJ Complete seal and gasket rebuild set $60
Brand new TVSV $150
Two new rear shocks $20 each
$90 for everything in blue
DNJ timing belt kit (includes belt, cam seal, crank seal, tensioner) $15
052-3179 Front Main seal $3
lower radiator hose $4
box of random water pump and oil pump gaskets $2
AC belt 39517 $1.50
ignition coil $14
starter solenoid $10
Autolite spark plug set of 4 $4 for set
Denso Spark plug set of 4 $5 for set
3 metal PCV valves $2
2 plastic PCV valves $1
1x cheapo Fram oil filter $3
2x Toughguard fram oil filter $6
distributor cap $6
NGK Plug wire set $15
Various things for engine rebuild VG1918 (looks like valve guides and giant washers that would go between rod and piston?) $5
Several carburetor rebuild kits when I find them
Also complete brakes and suspension, struts and springs for the FWD wagon but these might get sold with the wagon or installed
Used:
4WD shifter bushing (holds it into the transmission) $10
distributor (junkyard spare) $20
Set of gently used plug wires $5
Gently used distributor cap $5
front wiper linkage
2 carburetors that probably work
Cluster with 212k miles on it says "off when cold, works fine warmed up"
1 HAC (high altitude compensator)
87-88 headlight set see here: viewtopic.php?f=3&t=12606
five rear tail lights
Junk:
2 alternators for rebuild
2 carburetors for parts
starter for rebuild (might just need that solenoid)
The Professor:
ITM timing belt kit (includes belt, cam seal, crank seal, tensioner) $15
ES72073 Fel Pro Water pump mounting set
Water pump $10
1-2 used carbs $10
Marlinh:
8 Exhaust valves $2 each = $16
4 intake valves $2 each = $8
4 Keepers (valve stem) (free)
14 valve stem seals $10
Buzzard:
carb rebuild kit $15
trim and stuff
Lostfish:
distributor o-ring $1
8 valve stems = $6
seals?
prices are each:
Brand new TVSV $150
AC belt 39517 $1.50
ignition coil $14
distributor cap $6
Used:
front wiper linkage
Junk:
The Professor:
Water pump $10
1-2 used carbs $10
Marlinh:
Buzzard:
trim and stuff
Lostfish:
8 valve stems = $6
seals?
95 Camry Wagon, 170k
97 4runner, 275k
97 4runner, 275k
Re: Tercel Part blowout! EVERYTHING must go!
give us a price for the whole shebang
- BaileySims
I might need a few things! Let me know if you've got a spare ac compressor.
WAGON MAFIA.
Blood, sweat and beers.
No good AC compressor.
97 4runner, 275k
97 4runner, 275k
I would be interested in buying all the new parts from you if you give me a decent price. What do you want with for all the new parts?
I already have a lot used spare parts, so I do not need them.
I'll put something together for you tomorrow evening!
There's also more new stuff that we'll be unearthing as we have to clean the garage and the shed and reorganize before I can get started on the 95 Camry Timing belt oil seals gaskets and CV axle mega job.
97 4runner, 275k
97 4runner, 275k
I'd be interested in one of the timing belt kits and a carb to rebuild on the bench. Maybe the water pump and gasket too... Price on those?
all of the new parts I have needed in the past, and will likely need in the future. So if no one is in desperate need of any of them, I will be happy to buy the whole lot.
how much for the set of 87 headlights?
Hi Paul,
I would be interested in all the intake and exhaust valves you have. Plus the valve stem seals.
- GLet71
- My tercel:: '87 6-spd SR5 4wd Wagon
I'd go for seconds on the '87 Headlight assemblies, I'm rather invested in this particular year it seems.
Currently:
Formerly:
Formerly:
Damn, I missed the 87 headlamps! I'll get in line for those as well.
- seancromie
- My tercel:: (ROVER) 1987 tercel 4wd
im in search of coils up front and springs for the back of my 87 tercel 4wd wagon...
Sean mine are for the fwd.
Hey guys I'm out of town and forgot the laptop so I'll reply on Sunday to everyone.
97 4runner, 275k
97 4runner, 275k
- Buzzard67
- My tercel:: 1984 Toyota Tercel Delux
I would like Carb rebuilt kit. Please price for me when you find them. Do you have any interior pieces heater cables, trim, dome light cover dash nobes , levers ?
Please get back to me and I will make a list with Pics. Ok.
Later Buzzard
Later Buzzard
