HUMBLE BEE BRAKE UPGRADE
- My tercel:: "The Humble Bee" - Yellow 83 T4WD SR5 6spd and "The Goose" - Grey 86 T4WD DLX Auto (orphan to be saved)
I am excited to announce (what is quite possibly) the most perfect front brake setup for The Humble Bee! Everything is bolt on, without spacers, and only using off the shelf parts, nothing custom (just like I always do). This will be replacing my previous MK1b (88-89) MR2 caliper amd 98 Golf Rotor upgrade.
viewtopic.php?f=6&t=10513&start=15#p78841
The MR2 brakes performed BEAUTIFULLY, I highly encourage anyone interested, to do it. I will be rebuilding my MR2 calipers and I will use them to replace the stock brakes on The Goose, even though it is just a parts car.
I had a difficult time trying to decide on a brake setup even after narrowing down my choices to just three different calipers, all Toyota. I have decided to do the SMALLEST of the three. If anyone is interested in what the other two are, I have all the info you need.
My new swap may not be for everyone, as the parts can very hard to find or could be very expensive when you do. This swap will be very comprehensive, rolled out in phases, as parts arrive at my door. I have a HUGE list of part numbers, OEM and aftermarket (and even a few optional part combinations too) for a whole brake kit. Calipers, rotors, pads, master cylinder, brake booster, brake hose, and even brake fluid will be upgraded, SIGNIFICANTLY. The final list is complete now, just needs testing.
I am also going to do a full rear drum rebuild... for the lack of Corolla GTS rear end (at the moment) for a rear disc brake install (still searching, but SOON ).
Some may consider this quite a lot (too much) of a brake setup for just a daily driver commute... and it is, unless you drive like me . (Remember, my muffler fell right off due to rust, and I like it that way haha). At the minimum, you should install MK1b calipers. I don't consider the stock brakes to be safe enough... too much brake fade, too quickly, at too low a speed. Highway driving is when this is noticeable, not as much in the city.
I have enough parts now to at least conduct my test fitting of the caliper and rotor on the Goose. I want to make my measurements of the new caliper and the new rotor to check caliper/rotor offset. I have high expectations for a perfect fit this time around. I will test fit my caliper and rotor later today. I will post my findings in a write-up with some photos to come.
My new caliper is such a thing of beauty. I almost cried when I picked it up haha. Anyone want a sneak peek?
- Gottolovem
Re: HUMBLE BEE BRAKE UPGRADE
Let's see
WHO'S THE BOSS NOW?! haha
- Gottolovem
Ya sure that's gona fit without a spacer ?
You say your looking for GTS parts?
Wana buy a entire 87 fx gt-s?
Yes, I believe it will fit! It should actually give me more rim clearance than my MR2 ones. But I won't actually know until the test fit. The caliper bracket design is quite different, it goes OVER THE TOP of the caliper instead of the FRONT OF IT, like the MR2 ones do. My previous rim clearance issues were with the inside face of the rim, not outside diameter. From my measurements, the caliper to rim clearance should be better. As for the rotors, I expect them to fit even better than the Golf ones, because the "top hat" is 2mm shorter and the disc is 2mm thicker too. (my Golf rotors were +1mm for "tophat" and -2mm for rotor thickness AND my rotors will increase from 256mm to a full 260mm too).
hmm let's PM each other about that 87 GTS you got, I am very interested! The "rear disc" project is a WHOLE OTHER can of worms when you consider all the bolt patterns, axle sizes, and rear ratios. My best lead right now is a 4x100 axle from an 80's Toyota van combined with various SR5 and GTS RWD Corolla parts.
- My tercel:: 1983 4wd Wagon
What in the world...
Dual piston?
I need this.
Dual piston?
I need this.
Yes, please share your findings as soon as possible! Thanks!
- helipilot77
- My tercel:: 1984 SR5 wagon
Any updates yet?
- My tercel:: '84 SR5
Still waiting for an update to this!
Well, the last time the OP visited was a year ago this coming Saturday, so ...
- Rednecklawrence
- My tercel:: 5.5 Tercels total... Not enough
I've actually had contact with LeeBiew. He lives in Edmonton which is like a half hour from me. He hasn't fallen off of the face of the earth, so I could shoot him a text if anyone wanted...
If this brake upgrade is all he's hyped it up to be, then yeah, you should look him up!Rednecklawrence wrote: ↑Tue Feb 06, 2018 11:58 pm I've actually had contact with LeeBiew. He lives in Edmonton which is like a half hour from me. He hasn't fallen off of the face of the earth, so I could shoot him a text if anyone wanted...
