Repairing that awful fuel sender unit
Re: Repairing that awful fuel sender unit
Post by xirdneh » Mon Oct 05, 2015 12:11 pm
very good
lannvouivre
My tercel:: 2006 Pontiac Vibe
Re:
Post by lannvouivre » Sat Oct 10, 2015 10:46 pm
Iain wrote:...other than the sender being under the carpet in the trunk area on the al25....its the same...
Awwww, maaaaan! The carpet in the white Tercel is really gross. Why couldn't you just LIE to me?!
Huff! I guess I'll just have to rip the carpet out and burn it.
My tercel:: 1987 Tercel Wagon FWD
Post by irowiki » Sun Oct 11, 2015 12:04 am
it's under the bottom right corner of the cargo area, easy to get to
81 Coachmen RV, 65k miles
95 Camry Wagon, 135k miles
01 Camry Sedan, 265k miles
lannvouivre
Post by lannvouivre » Sun Oct 11, 2015 1:53 am
irowiki wrote:it's under the bottom right corner of the cargo area, easy to get to
Yeah, but I'll still have to feel the slimy grimy feeling through my gloves!
cabinguyvt
My tercel:: 1983 SR5 4x4 wagon
Post by cabinguyvt » Sat Feb 20, 2016 12:59 pm
Perfect!! Got mine out and thought no way this is ever going to work again....cleaned it all up, tested per your instructions, ought to work. Re-installed in car, and low warning fuel light came on, then gauge started creeping up the gauge. What a help all these tips are!
Jonymoto
Post by Jonymoto » Sun Feb 21, 2016 3:51 pm
Does anybody know how to make the needle on the fuel gauge line up with the full mark when the tank is full? At the moment it stays between 3/4 and full. I have the same problem with my wife's 2003 Rav4.
Post by dlb » Sun Feb 21, 2016 4:07 pm
the repairs mentioned in this thread should fix your gauge not reading full. it's usually due to some kind of buildup on the contacts on the fuel sender so it just needs a cleaning.
Jonymoto
Post by Jonymoto » Sun Feb 21, 2016 5:10 pm
Thanks dlb, I will pull it out tonight and clean it with carburettor cleaner. The other thing I noticed is that when the tank is almost empty, the needle goes down much lower than the empty mark. It's almost like the range from empty to full has shifted.
jaydee911
My tercel:: 87 t4wd
Post by jaydee911 » Wed Nov 16, 2016 11:09 pm
Pesky to say the least. I set my timing and thought I was getting amazingly better fuel economy!
Nop. Gauge diddnt move for a week of driving to work in back. (20 km a day)
So went to go pull my unit (no pun intended) and the 6 Phillips holding it are rusted to shit. Only could turn one screw :(
Weird thing to is after plugging it back in the needle dropped from just over half to just under... WHY MUST YOU LIE TO ME!?
emergency j can of gas in the back smells bad but will due for now lol.
87 tercel wagon
87 toyota pick up 4" on 33s flat bed
Post by Petros » Thu Nov 17, 2016 3:29 pm
use your miles to confirm how much fuel you burn. II reset the trip odo every time I fill up as a back up to my gauge. though my gauge is working fine, the more info on how the car is running the better. bad fuel economy indicates something needs to be fixed.
soak the sender screws in ATF, clean out the philips heads with solvent and compressed air if possible, and put your weight on them when try and back them off. might help to give each one a sharp wrap with a hammer before you try. Several days with ATF on it usually is all it will need, it is the best penetrating oil yet invented.
Post by xirdneh » Mon Nov 21, 2016 12:11 am
use a vice grip
JDNightFox
My tercel:: 1986 SR5 / 1987 SR5
Post by JDNightFox » Sat Apr 08, 2017 3:34 pm
None of the pictures are showing up in here because I guess they're too old to be maintained
I've been having the same issues mentioned in here and I pulled the sending unit out with no issues (no rusted screws, no rust on sender itself, it looks pretty new still)
I jumped the connector and the needle went up to the full line so it's not the gauge
What exactly am I looking for on the sender to bend / clean / fix? that metal box thing at the top that's sealed doesn't look like it can be pulled apart
Post by ARCHINSTL » Sat Apr 08, 2017 5:43 pm
JDNightFox wrote:None of the pictures are showing up in here because I guess they're too old to be maintained
waynehoc's have disappeared, but those of tercle, Mad_Marx, and 4wdEconoBox appear to me.
Oh, do not ask, 'What is it?' Let us go and make our visit.
Now and then we had a hope that, if we lived and were good, God would permit us to be pirates.
Post by Petros » Sat Apr 08, 2017 7:28 pm
JDNightFox wrote:What exactly am I looking for on the sender to bend / clean / fix? that metal box thing at the top that's sealed doesn't look like it can be pulled apart
no need to pull it apart (in fact, I would not). there is a metal leaf with a contact on the end that slides over a fine wire coil (wire wrapped around a card), it changes the resistance as it sweeps over the coiled wire, which is how it changes the reading on the gauge. you do not have to have corrosion present for it not to work.
Inspect the contact carefully, it must make contact the full distance though the arc of movement. you should clean off the contact and the coil with very fine steel wool (clean it up good when done), or a pink pencil erasure. IF it dose not make contact you can carefully bend the metal leaf so it puts light contact pressure on the coil. Usually that is all you need to do. but also check all the other electrical contacts in the system for continuity, sometimes you get corrosion in the contacts that is not obvious.
