good starting then rough idle
My (Canadian, 1987) non-computerized, 5-spd manual trans wagon has always idled a bit rough when cold, for the first few minutes, particulary after sitting either overnight or for 8 hours or more while I'm at work.
Reason is, I think, that Canadian 5-spd manual wagons do not have the carb float bowl vent to the charcoal canister, so on shutdown all the fuel that evaporates from the bowl is just 'captured' in the air filter assembly. So on a cold start. the carb is running rich until all that evaporated fuel is sucked into the engine and burned. Don't know why Toyota didn't do the float bowl vent to canister thing with our Canadian manual trans wagons.
