I'm wondering if anyone else has or has had and repaired this problem.
It's done it since I got the car..
anything below about 1100rpm (Idle is around 800-850 when warm) everything in the car dims, dash lights, headlights, the heater fan slows down if its on, etc.
I didnt care until I put a power inverter in the car and it beeps when voltage drops below 11v or something around there I think. It does it almost every time I stop at a red light or stop sign and its darn annoying
I've had mixed responses from possible slipping belt to bad battery to bad alternator to bad ground[s]. I'm just wondering if this is a common issue and if there is a "most probable" cause for this so I know where to start.
I haven't even checked to see if the belt is slipping yet even though thats an easy one - I just haven't been home during daylight recently working 12h days
Any input is appreciated
Voltage Dip
My car does that too...seems to me a lot of my little 4cyl toyota's have. Not sure if it's normal or not...
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
Same. Some days worse than others.
We could really use a bigger alt...
Bigger battery will help.
A few extra grounds, well placed in a well-thought out manner never did any harm.
You might need a new belt. I know I do.
