i am on the verge of replicating the copier beatdown scene from the movie office space with my feedback carb.
my car: 1988 toyota tercel (automatic) w/ 3E engine.
my question: has anybody ever heard of/performed a weber conversion on this particular year/model?
all of the literature I can find about the weber 32/36 does not list the 3E as a motor that can take the conversion, however the 3AC is listed, which I believe has the same intake manifold... right?
any and all info. about this potential conversion will be paid back 100x karmically.
thanks!
casey
Weber 32/36 conversion on 3E engine... possible?
Re: Weber 32/36 conversion on 3E engine... possible?
I haven't heard about it being done. I do know that the stock 3E carb is the worst thing toyota ever put on one of their engine's though. I don't see why you couldn't put a weber on the motor. The main trick is that you may need to have a custom carb to intake manifold adapter fabricated. But if the intake manifold is really the same as that on the 3A, then you should be able to use the same adapter kit. You may want to check that there is enough clearance for the carb under your hood.joes mama wrote:i am on the verge of replicating the copier beatdown scene from the movie office space with my feedback carb.
thanks!
casey
Just my two cents.
Current:
91 LJ78 Landcruiser EX5
95 A32 Maxima SE
Former:
87 AW11 MR2 Smallport 4AGZE
93 Taurus SHO ATX
86 AL25 SR5 6spd 4wd
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
95 A32 Maxima SE
Former:
93 Taurus SHO ATX
90 AE92 GTS
82 KP61 SR5
85 MX73
87 AE86 GTS 4AGZE
85 AE86 GTS
83 AL21
