Same safe max size I read somewhere.LowBuckCanuck wrote: ↑Wed Apr 18, 2018 5:50 pmI'm pretty sure the max for 14 inch rims without lift is 195/75/14r, I personally wouldn't go much bigger even with the lift.
The Definitive List of Ways to Lift a Tercel 4wd
Re: The Definitive List of Ways to Lift a Tercel 4wd
- C130
- My tercel:: 1984 SR5 280K Lift and 195 75 14.
Here is the invoice for the retreads I went with.AbraCadaver did all the research and found these bad boys.
- seantp
- My tercel:: 1983 SR5 4WD Wagon
Thanks! Not a bad price at all.
- travelbyota
Can anyone confirm this will fit without lift? Thanks,Termell wrote: ↑Wed Apr 18, 2018 8:56 pmSame safe max size I read somewhere.LowBuckCanuck wrote: ↑Wed Apr 18, 2018 5:50 pmI'm pretty sure the max for 14 inch rims without lift is 195/75/14r, I personally wouldn't go much bigger even with the lift.
K
79 Subaru Brat 4WD, 84+85 Toyota Tercel SR5 4WD, 85 Toyota Xtra cab 4WD, 07 Subaru WRX AWD turbo
- seantp
This might be helpful. It shows stock 175/70 R13 vs 195/75 R14. I am still wondering how soon they would rub when turning.
- travelbyota
I'm lifting later down the road and was looking to get rid of the rubber band tires on it at the moment. I can see the issue arising near full steering lock using just a tape measure. I'll probably do some 185 75R14 snow tires to fill the wheel arches up for now...thanks for the info!
K
K
- LowBuckCanuck
How much do the Monroe ma700's leak down over time? I installed a set, and they are dropping about 5-10 psi every day.
I already had one shock out to re-weld a garbage bead around the top of the shock. I will probably have to do the other one. Not impressed with the factory weld quality.
spray some soapy water around the hose fittings to find you leaks,, dont over tighten them,mine set from november till april lost 3psi
- My tercel:: 89 Toyota Tercel coupe
I have a 89 Toyota Tercel coupe fwd I was wondering if the #2- The Abra-Cadaver Lift will work on mine since it’s 2wd not 4wd. Thanks
not likely, the design of the suspension and drive train is completely different, you have the 3rd generation design Tercel. Much has changed in the model change over.
the same ideas may work, but you would need the correct parts to make it work.
Dam okay thank you. Would anyone happen to know anything about this? Or have some sort of knowledge on the subject lol iv been looking for ways to lift it for awhile now and can’t seem to find any information on it
- LowBuckCanuck
If your car has macpherson struts front and back, I would recommend the cutting board/spacer lift. That is what subie owners do to get some lift.Sevinatenine wrote: ↑Mon Jul 30, 2018 7:13 pm Dam okay thank you. Would anyone happen to know anything about this? Or have some sort of knowledge on the subject lol iv been looking for ways to lift it for awhile now and can’t seem to find any information on it
What brand of lift kit can you suggest?
- LowBuckCanuck
I would suggest the "picknpull" brand: go find the parts that fit, and gives you some lift, trial and error. cheap and fun experimenting on your own car.
