Removing the rear washer nozzle on the T4WD rear hatch
SynthDesign
Post by SynthDesign »
So Petros pointed this out and I gotta post it. Maybe it's so simple and that's why I missed it.
You'll need a dental pick or such and a thin needle nose pliers.
To remove the rear sprayer(most likely from the junk yard to replace your broken one) remove the round rubber seal which is attached to nozzle and touches the hatch, it can be pryed off like an o-ring using a dental pick. Squeeze the two tabs in and the nozzle slides out. Detached the rubber hose and re-install. The seal can be placed on the nozzle before installation because it just snaps on.
(Pics go here when my computer stops messing up)
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
Re: Removing the rear washer nozzle on the T4WD rear hatch
good info! i couldn't figure this out when we removed the hatch to paint ron. we wound up just cutting the wiper fluid hose and then splicing it back together afterward. worked fine but doing it the right way would obv be preferable.
Mcmattlds
My tercel:: 83 4wd ..lifted custom exaust all sr5 add ons
Post by Mcmattlds »
Oh hey found that 2 and 3rd gen 4 runners have the same identical peice..
Mad_Marx
My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Post by Mad_Marx »
Does anyone have pictures of this procedure? I need to replace mine and i cant seem to access the backside through the rear hatch, no access hole in the steel body pannel?
no need to access behind it, it removes the outside. you remove the thick rubber gasket on the outside of the nozzle (hook under it and stretch it off over the top of the nozzle). ONe the gasket is out, that allows you to depress the two little tabs that hold it in place. all done from the outside. Not obvious, but once you figure it out you will see it is easy.
