Transmission problems
Re: Transmission problems
i hope you save the old tranny
wreck yards usually want the old one as a core (usually 100.00)
i would give you 100 for it
being stuck in gear could be
broken tranny
shift rod is bound up where it enters tranny (this can be freed up) if water is in the shifter area when you remove shifter assy that would be the first thing to try
and last but not least a longshot requiring a combination of things to occur. if stuck in neutral. if previous owner dissconnected tranny from bell housing and reconnected it, the lower shift rod could have been bumped causing it to get stuck in neutral. and maybe thats why it ended up in the wrecking yard.
i sent you a PM and Email recently
BaileySims
Post by BaileySims »
If it has a decent steering column cover, I would like to buy that from ya.
WAGON MAFIA.
Blood, sweat and beers.
NotYourHairyUncle
My tercel:: 1987, sr5
Post by NotYourHairyUncle »
Well it only took about 8 hours of work to get that transmission out haha :lol: :lol: :lol: . 4th transmission I've ever removed and my first 4wd tranny.
Big thank you to Petros for the advice about prying that radiator out of there you helped out significantly :D
As far as the inclinometer goes it was swiped before I got there sadly. And I didn't see the message about the stearing column cover until it was too late sorry bailey. However I did talk to one guy at the junkyard who said it will be there for the next month so I plan on going back probably on Tuesday to pick up some cosmetics and guts for the passenger side door.
I was hopeful that it was a newer transmission swapped into an older model because one electrical hookups was just hanging there with no wires in sight. Also the engine was remanufactured but upon further inspection I'm almost positive it's an older model.
Xirdneh I'll message you soon just been super busy
TL/DR..... mission accomplished I'm going to be holding onto this tranny for a while just incase mine shits the bed.
NotYourHairyUncle
One more thing, I grabbed the driveshafts because I was worried about the gear differentials not being the same thinking I would need them. I realized I was being a bit silly and ignorant. There is no reason for me to keep them is there?
Also on a side note say I was to swap the rear axel from the 83 to the 87 alongside the transmission would that allow me to use 4wd without any problems? Assuming I hooked everything up correctly
[quote=Also on a side note say I was to swap the rear axel from the 83 to the 87 alongside the transmission would that allow me to use 4wd without any problems? Assuming I hooked everything up correctly
[/quote]
swapping entire rear axle is not necessary and would be a lot of unneeded work
pull the axles out of each end and get the differential only.
also if you seperate the tranny from the front diff housing you can use tranny (only) in any tercel, not having to worry about diff ratios.
if the drive shaft universal joints, and center carrier bearing is good, the drive shaft assembly is worth keeping. the bearing and u-joints should be smooth rotating. the u-joints wear and start feeling "notchy" when you rotate them.
since you removed the cv axles, I usually take them too if they are good (boots in good condition and all joints with no rotaional play and rotate smoothly), you can buy them new for $60 each, so do not pay to much for them, but if good they should last a long time.
these parts wear out and are worth keeping as spares.
BTW, that looks like a great price for the parts you bought.
great price.
early trannys have two electric plugs
late trannys have three
the only sure way to know what the gear ratio of differential is is to remove cover and count teeth on pinion (small) gear
11 teeth is early models 83-84 3.73 ratio
10 is late models 86-88 4.1 ratio
the 1985 year is still a mistery to me
rer233
My tercel:: Multiple
Post by rer233 »
'85 has the "late" (4.10) ratio.
NotYourHairyUncle
Haha well the tranny finally bit the dust. Was on the free way of course doing 75 and it was making a funny noise in 5th then all of a sudden it pops out and won't engage in gear. Any idea as to why all of a sudden it would refuse to engage in gear? It stays in gear but no wheel movement Almost like an cv axel came loose or something. Haven't crawled under the car yet but planning to as possible.
if front axles are ok, not broken or not popped out of differential
if it will not attempt to move forward in any gear i would say the main idler gear and probably input shaft gear teeth have stripped off
sometimes the stub axle or spline shaft on the CV axle fails, and it will act this way.
main shaft failure of the trans, or as Xirdneh points out, gear teeth gone. if running low on gear oil these get lubrication starved and causes it to get stripped of teeth.
NotYourHairyUncle
So the passenger side cv axel inner boot was punctured. It seemed fairly recent but no way to be sure. Oh well gonna throw that junkyard tranny in, tired of not having first gear haha.
NotYourHairyUncle
Anyone know the socket size for the bolt that connects the cv axel to the rotor? Biggest I got is 32mm but I believe that's too big. Also is it a 24mm for the drain plug?
