Just bought this. It's been sitting for 16 years. Was used as a dingy behind an RV. Only 63000 miles. Judging from the interior it was mostly towed miles.
I have revitalized the fuel system and it runs!. I'm getting new tires and looking at the braking system, no pedal.
Awesome car. Wish me luck with it.
https://photos.app.goo.gl/hbGIz4ZzyX4xnmcx2
New to Forum and Toyota 4wd
- My tercel:: 1984 SR5 4WD
Re: New to Forum and Toyota 4wd
welcome to the forum.
Looks like a great find. if it sit around a lot the belts, tires, and seals tend to dry up and crack. So once it is running, watch your front and rear engine seals (front crank and cam not so bad to replace, rear main seal is a lot of work, must drop the trans).
If you are replacing brake parts anyway, consider doing the front brake up grade I have outlined over in the repair guides section. new parts are about the same cost and improves braking considerably.
you can put in the front rotors and calipers without having to do any other mods.
good luck.
good luck.
Beautiful body!
First thing is to change the tranny/diff fluids. There is a definite drill to that! Do a Search for the procedure.
Also - download the FSM - link is a sticky in the General Forum.
Welcome!
Welcome!
- bryanthompson
- My tercel:: 1983 4WD SR5 Wagon : "The Brochure Car"
Welcome! That blue is such a nice color. Congrats
