Hello from Slovakia
Re: Hello from Slovakia
Hi Jojo, I think the 4efe is more power than that and is fuel injected and 88hp so more than the Tercel 3ac. but you would need the ecu and fuel pump put into your car! I hope someone else can give you advice on the 3ac
check your exhaust valve guides are firmly in place. I have seen the valve guides come loose and start popping up and down with the valve stem. it can run fine, but oil leaks like crazy into cylinder.
review my head gasket procedure in the repair guides section to get it back together. I show how to resurface the head and block with hand tools. you can also hand grind the valve seats too using a grinding compound and spinning the valves in place to polish the seat.
viewtopic.php?f=7&t=6059
Jojo
My tercel:: 1986 4wd
Post by Jojo »
Thanks, I am gonna check valve guides. Head surface is corroded and after cleaning I am not sure if it is flat enough. (But I did not checked it properly, only by view against sunlight). Today it is last day of summer heat in Slovakia (according to forecast) so I will be able to work in my workshop again. :-)
Jojo
Post by Jojo »
Valve guides are good, no movement.
than likely bad vale seal, or possibly really worn valve guide (though they tend to wear evenly, so odd one would be leaking so much oil). the pressrue galley for the oil supply to the head is up front in the corner, it is possible the seal in the head gasket got compromised and leaked into the front cylinder, though that seems very unlikely. or a possible crack in the oil galley in either the head or block, which is also very unlikely in a Toyota engine. I have never seen a cracked Toyota engine or head, unless it was physically damaged like it broke a connecting rod due to running without oil.
One other possiblity is damage to the #1 cylinder rings, or piston. or badly damaged cylinder bore. I have seen all three cause excessive oil into the combustion chamber.
While it is apart you must determine the cause of the oil getting into the one cyclinder, or you may go to all that trouble and costs and not fix it. If you can not find any problem in the head or valve train you will have to pull at least the # one piston and get a good look at it. You may have to just re-ring, or possibly replace all four pistons.
you can not put it back together until you know you fixed the problem, you will waste time and money if you do not find and fix the cause.
good luck.
Jojo
Post by Jojo »
Update:
My options were not hopeless, but a bit expensive.
1. 200 euros for rebuild of cylinder head in Poland (extraction of broken screw, repair of that mess and repair of weared camshaft bearings surfaces). Which was extactly 50 euros more, than I paid for whole car. :-)
2. 75 euros for another used cylinder head from Hungary.
3. Complete engine swap. Corolla engine for about 120 euros.
4. After a month I found a fellow not more than 30 miles away, selling something I could call a rest of Tercel. I made a swap deal with him. My broken Trabant (east German communist two-stroke engine car with trunk filled with spare parts) for his Tercel with working engine + his additional payment. :-)
I tow it home on a bar yesterday evening. I cut my back thigh muscle on windshield glass dropped on seat in a process (4 stitches on ER) :-)
But it seems to be a good deal for me - engine works fine, with no smoke at all. It has original carburetor and other parts, which is a miracle. According to licence plates car was not registered for 20 years.
sounds like you made an excellent trade: a Toyota for an obsolete communist built car. I would make that trade any day.
You will have a lot of other parts you should save off it too, especially save the transmission.
Good you got the car running, and have some spare parts too!
Rednecklawrence
My tercel:: 5.5 Tercels total... Not enough
Post by Rednecklawrence »
Aww, I feel bad for the red tercel :( poor guy
Jojo
Post by Jojo »
Rednecklawrence wrote: Sat Sep 30, 2017 11:40 pm Aww, I feel bad for the red tercel :( poor guy
Me too, someone destroyed it just for fun...
Jojo
Post by Jojo »
Everything that could be broken is broken. All lights, bulbs, inclinometer, instrument cluster, etc.
Rednecklawrence
Jojo wrote: Sun Oct 01, 2017 12:10 pm
Well, at least it's giving another Tercel a new outlook on life
Jojo
Post by Jojo »
Is this normal or is car repainted from white to green/silver?
not normal.
looks like the car was repainted, but that looks too clean (and kind of odd). Perhaps an earlier owner had cleaned up a rusty underside when the trans and drive train were out of it, and repainted it white?
the only Tercel I have seen with the same front as yours were all painted white. It was a Europe only thing.
Jojo
Post by Jojo »
I cleaned it just to be sure about color. I suppose it is original color, too. Maybe one of previous owners had good white and bad green car (but with licence plates) so he made a paint job and result this hybrid. I love cars with history. :-) ).White looks nice, so I am thinking about repainting it back again after bodywork will be done.
