RIDLBOX yes that's the cars name
Re: RIDLBOX yes that's the cars name
those are in a place hard to get behind. I have fixed a few of these this way: remove all of the inteiror panels and the tail light, use wood block and boards, and a big pry bar to get behind it. be careful you push in the correct place, do not bang on it, but lever and push it out. Using the blocks to get leverage in the correct place. cut and sand the bock to fit the inside curve of the body panel, and add a thin layer of padding (cardboard, heavy fabric, thin foam padding, etc), and drive it against the back of the dents.
If done carefully you can even save most of the paint. at the "eyebrows" you have to get it slight above original contour, and than use a plastic mallot to tape it back to shape (with the wood block wedged behind it). This way you will use the min. amount of body filler.
sometimes on minor dents you can do a "paintless repair" (go see Youtube for paintless dent repair process). where you can carefully bring it back out to contour without damaging the paint. of course part of that dent has already rusted, so you will have to sand and fill the corrosion. But the less filler the better.
A few times I have made dents like this almost go away, so much so that I choose not to add filler, but left it as a slight dent that was hardly noticeable. Rather than put on filler and after market paint, which is never as durable as the original factory paint.
good luck.
Notmikeb
My tercel:: 85 Tercel 5dr FWD
Post by Notmikeb »
Using a heat gun on the area before reshaping not only makes the metal slightly more pliable but increases the flexibility of the paint. Greatly reduces the chance of cracking the paint in the process. Obviously be careful not to keep the heat in one place too long or the paint will bubble and that's just as bad.
1985 Tercel 5dr Hatchback
2003 Chevy Suburban
2014 Ford Flex
Ridlbox
Post by Ridlbox »
I think I'm going to put those two together use a little heat and some two by fours and lightly push not going to try today not sure when I'll start it Body Shop told me the car is so old there's no point in doing it, ... if it was a 57 Chevy you would have pulled the dents out what my cars not old enough for him
That's my new goal 8)
he is telling you he does not want to work on it. I hate when mechanics express opinions that are unsolisited, sometimes they are tring to be helpful, but they are usually clueless when it comes to older cars.
Ridlbox
Post by Ridlbox »
Thought I would post a brand-new picture of the Rattlebox taken yesterday with my dad's car
The hounds are on the loose! where was the photo taken? looks like a camp ground. very nice.
Ridlbox
Post by Ridlbox »
Was taken in my dads front yard
what part of california is that? Looks like perhaps sierra foothills east of San Fransisco or Sacramento.
Ridlbox
Post by Ridlbox »
Photo is about halfway between Sacramento and Lake Tahoe on the mountain literally right in the middle of the wilderness
Gottolovem
Post by Gottolovem »
Abra-Cadaver wrote:
Auburn?
Placerville ish
