At long last! My first tercel
Re: At long last! My first tercel
You'll want a new gasket, and you can get them in a rebuild kit!
- cromagmom
- My tercel:: 84 Tercel 4wd
Put an order in for one. Should be here on Monday. I lost the o-ring on the primary solenoid somehow, too, so the kit will be extra useful. I don't think I have the guts to do a complete rebuild after messing up this simple cleaning...
full carb rebuild is easy but not necessary if you don't have any issues that are not resolved by going over all the emission and vacuum stuff first.
very odd the float level is not visible when cold. try this: with the engine off, keep opening and closing the throttle while alternately looking down the first barrel of the carb and at the sight glass. you should see a squirt of gas into the first barrel every time you open the throttle. if you do not, that means the float bowl is emptying with the engine off. if gas keeps squirting until the level comes down into view, the float bowl is overfilling with the engine off. that will give you a better idea what to look for to fix it. let us know what you find.
I have reused torn carb cover gaskets, put fuel resistant gasket sealer on it, all surfaces exposed. should work okay.
make very sure you have all the tiny internal parts in place before you put the carb back together. worst part about a carb rebuild is keeping track of the tiny parts, and getting them all in place properly. Many are not held in place, but are there loose and relay on the top to hold it in place.
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
I had the rough idle and hard to start issue with my first Tercel, I found and fixed an intake manifold leak, and added a block heater. Started much easier after the intake leak repair, even when the heater wasn't plugged in. Later I ended up replacing the factory carb with a rebuilt, that helped too. Now I run a weber, it doesn't start/run as nice as the factory carb did on cold days.... it's always something :/
- cromagmom
Starting has been tougher despite warm weather. I used some fuel cleaner and it seemed to start happening more after that. It usually takes 2-5 times from cold to start up after starting, revving, then dying.
I'm going to try some sealer so I don't have to wait for the kit to get here, see if I can find the right solenoid o-ring from the parts store, put some blades on the solenoid wires because those have been the most frustrating part, and run dlb's test.
Still feeling car ignorant though...would the intake manifold be where the carb bottom mounts?
If you used fuel cleaner and now it is running wonky, try changing the fuel filter.
yes, this is correct.cromagmom wrote:Still feeling car ignorant though...would the intake manifold be where the carb bottom mounts?
- cromagmom
Found this in the float bowl and I'm not quite sure where it belongs
the outer diameter is the same as the inside of the pump plunger.
is that a donut bushing or an accordion-style boot? if it's a donut, i don't remember seeing one like it in the carb but if it's an accordion boot, it probably goes at the top of the power pump or whatever that plunger thing is called.
- cromagmom
It is definitely donut shaped, pretty thick (2-3 mm) The accordion is in place on top of the air horn body with the pump plunger. It fits perfectly inside the pump plunger, but that doesn't seem like a spot that needs a bushing.
there is an important seal that goes between the top cover (what the fsm calls the air horn) and the main body. It sits on top of the center area between the two barrels, it is held in place by the top cover. It seals off an important air passage way that regulates the air/fuel mixture. It is about 1/4" around (6 mm) and an 0.125" tall (3 mm), square edges. looks likes a very short piece of hose. Usually it is stuck there when you pull the top off and it stays in place, but it is easy to knock loose and not know where it comes from (or loose it altogether) if you remove the cover. there is a slight recess that holds it in place.
That one in the picture looks too large to be the one I am talking about, if you leave it out (like I did once) it will start and run but run crappy and be down on power.
Did you find that in the carb when you took it apart for the first time? Or did you find it after you had attempted to fix the carb? It looks like a grommet, but I can not think where else it goes.
- cromagmom
That's exactly it, Petros. I found it after messing around with the carb for a bit. The inner diameter fit perfectly, and it would make sense that I accidentally knocked it into the float bowl.
here pick of it sitten between the two screwheads left side
wow, that float bowl is filthy.
