Front Struts question
According to the FSM, the front strut assembly cannot come apart, however, in looking for a new strut assembly, everyone lists cartridges only. The FSM says that by loosening the bug nut at the top of the cartridge (if it is a cartridge) lets the gas out, it is a gas strut.
The car was built May 86. The strut diameter is slightly over 1.75". Do I go for it and undo the bolt?
A couple of you keep referring to the 1.75" ones as "rebuildable". Do you mean they can take a new cartridge or you take them apart, put in new seals and oil?
BTW, I have searched through all posts relating to the front struts and I think it only made me more confused, since it doesn't tally with the FSM.
Re: Front Struts question
Ditto for me - I will be replacing my struts and springs this Summer - and am glad someone else is as confused as I am about this. Mine is also an '86, albeit built in October of '85.keith wrote:According to the FSM, the front strut assembly cannot come apart,...BTW, I have searched through all posts relating to the front struts and I think it only made me more confused, since it doesn't tally with the FSM.
Patience isn't one of my strong suites. I took it apart.
This looks like one I would define as rebuild-able, that is new seals and new oil. It is supposed to have a gas charge but I guess that leaked out a long time ago, I didn't hear any hissing when I undid the retainer. If I can put in a cartridge, I plan on using either a Monroe sensatrac or a KYB GR-2 cartridge. I'm leaning to the KYB at the moment.
coltarms, Is this what yours looked like inside? Can I put a cartridge in this now?
Anyone else, does this look familiar? What did you do?
I guess she'll be looking like this for awhile.
BTW, this didn't start out as a strut project, I was going to put in the EMPI axle, when I undid the strut bolts on the hub, the strut fell out, broken upper mount. See jammin1911's post on Wheel Bearing disaster post below (or above if anyone else responds to it).
Throw in Gabriel for opinions.
These 3 brands seem to be the most prevalent, at least in North America.
Effectiveness [at least on-road (I'm realistic...)] - longevity - ease of installation - any other pertinent comments ?
The pricing on all seems relatively similar; O'Reilly has a slight edge over AutoZone for Gabriel - Advance and NAPA have close pricing. I'm talking cartridges, mounts, and cushions.
Any opinions on springs? Again, for street usage.
My Sensa-Tracs work great... For the first 500 miles or so. Then my bad coils combine with my lack of bump-stops to punch the valving out and get me back where I started. Thank you Advance for free replacement! I'm on set 3. I'll wait to put in more for when I can get new springs and a bumpstop.
My Sensa-Trac shocks in the rear have held up fantastically for the past 30k or so. When I get new springs I might try to finagle some new ones though.
With my '83...there is no cartridge...and the diameter of the strut tube as measured on the outside is different. Couldn't find a cartridge to fit...so I filled the one I had apart with Mobil synth ATF and reassembled it.
Some claim to have found whole rebuilt assemblies...spring perch, cartridge, and tube.
I did determine that there were at least 2 different strut tube ODs...larger diameter = the cartridge type?
