Terc doesn't like warm idle
- My tercel:: 1987 tercel 4wd sr5
Hey all, up until yesterday my turd has been running great, however the car once warm wont idle at its normal 900 rpm it had before. The car will run perfectly fine when given gas and I have been able to just barely get to and from work by keeping my foot over the gas when not in gear. I'll be changing the spark plugs tomorow morning and I'll be poking around the carb as I have never fiddled with it, I'll check for vaccuum leaks and such but any help or tips would be very much appreciated. Thanks all!
Re: Terc doesn't like warm idle
Check fuel cut solenoid on back side of carb. You can disconnect large green plug (with wires from carb) to expose terminal blades. Solenoid may be single or two wire depending on year. Supply positive juice to single or pos and neg to two wire. Listen for "click" . if no click its not working.
Check vac lines for leaks, especially the one from base of carb to air filter housing.
- Mark
The EGR vacuum modulator is only active when the engine is warm. It has a diaphragm in it that might be leaking, causing a rough idle when warm. That's what happened to me anyway. You could try disconnecting/plugging the vacuum hose to it and see if the idle improves.
Thanks for the help guys! Is the egr modulator nearer the carb? Smaller circle piece, UFO shape almost?
yes, that sounds like it. It has a 12 mm dia tube that runs to the exhaust manifold that gets as hot as the exhaust, and it should have a vac line running to the UFO thingy.
