Fuel Issue
J Dumarais
My tercel:: Toyota Tercel 4WD Wagon '86 & Jose 87' Tercel 4WD Wagon
Fuel Issue
Post by J Dumarais »
I have that draging feeling went i got to push the gaz more to go up hill or take some speed. It seems to be unrelated to speed and no constant rythme. I change the fuel filter, but it still getting worst. Carburateur need a clean up?
I'm on Vancouver island rigth now, i'm looking forward to know all the bugs of my Tercel.. Any BC membre would want to give me a hand or know a good old school Toyota mecanic i could visit?
Re: Fuel Issue
if spark plugs, cap and wires are old, they tend to break down and cause misfires when under load, power drops off. Also, verify that your mechanical advance is free and working properly. if it gets corroded and will not advance you loose power at higher rpms.
Try replacing those first if any of them are old or appear compromised. A failing coil or ignite can also cut out under load, but unless there is an obivious flaw, best diagnose those so you replace the right part.
good luck
J Dumarais
Re: Fuel Issue
Could it be a timing issue ?
atoyta
My tercel:: 3 wagons now
Re: Fuel Issue
Post by atoyta »
Mine will run poorly due to corrosion in the distributor cap & on the rotor including the brass contact on the rotor where the carbon contact touches it. I clean the contacts with 1000 grit sandpaper every so often.
J Dumarais
Re: Fuel Issue
Thanks you! Distributor cap connections was totaly good to go!
