Lost throttle & rpms when driving won't start
Nwtercel1
Post by Nwtercel1 »
I was driving up a hill at 45 and my rpm gauge dropped to zero and I lost all throttle now I can't get it to start
Any ideas where I should start
I turns over and try's to start
Re: Lost throttle & rpms when driving won't start
Is distributor loose?
Only time one of mine did something like that the timing belt broke. Engine cranked over much faster than normal but never fired.
jimcrazy
Post by jimcrazy »
i have had that happen twice to me over the years,something in the distributor gave up,,swaped in another distributor and carried on,,never brothered to test to see what gave up as I have a half dozen spares
rer233
My tercel:: Multiple
Post by rer233 »
Same here- did you check for spark?
Nwtercel1
Post by Nwtercel1 »
Thanks everyone
It does appear to be distributor and I am in the process of finding another to swap in
Timing belt may have lost some teeth
check the timing belt first, it will not spark with a broken timing belt because the cam is not turning the distributor.
if timing belt is okay, verify cam (or rotor in distributor) is turning when you crank it (to eliminate any mechanical failure in the system). even the distributor shaft can fail. so if everything mechanically is good, than swap out distributor.
if cam is not turning, a new distributor will not help.
Nwtercel1
Post by Nwtercel1 »
Will do I will report back
Thanks!
Nwtercel1
Post by Nwtercel1 »
Turned out to be distributor
Back on the road
