Identify the part...
Nwtercel1
Post by Nwtercel1 »
I am having trouble with my 85 Tercel idle I believe this is the culprit I just dont know what it is called. Can anyone help me?
I appreciate it
helipilot77
My tercel:: 1984 SR5 wagon
Re: Identify the part...
Post by helipilot77 »
TVSV (Thermostatic Vacuum Switching Valve)
Toyota part number 90925-02076
. / TOYOTA
./_| |/|/ |]
you might be able to repair it, there was a thread on this topic (requires epoxy and wiring it back together so it does not leak vacuum).
you need the TVSV to run properly, though it might be possible to by pass most of the systems this operates, to rig it so it is in the normal "warm and running" condition. It means the cold starts will be balky until it warms up, but otherwise should run okay.
rer233
My tercel:: Multiple
Post by rer233 »
If the repair doesn't work out, the Toyota P.N. is 90925-02076, available on the web for $120-$140.
helipilot77
Petros wrote:you might be able to repair it, there was a thread on this topic (requires epoxy and wiring it back together so it does not leak vacuum).
Here is the link to the thread you mentioned Petros, however the pictures don't seem to be working anymore. :?
. / TOYOTA
./_| |/|/ |]
rer233 wrote:Toyota P.N. is 90925-02076, available on the web for $120-$140.
some times you might get lucky and someone gets a small supply of them cheap, they list them on an e-bay store for $30.
So reguarly check different sources, including Rockauto.com, Amazon, Partsgeek, and ebay. the prices will typically hover around $120-130, and than suddenly someone clears out an old autoparts store or warehouse, and 12 will show up for $16 each...and than they are gone.
here is an ebay link for a "Genuine Toyota Tercel Valve 90925-02076" about $140 includes shipping. about half what a toy dealer might ask, if the have any in stock.
http://www.ebay.com/itm/like/2223482770 ... noapp=true
what about a wrecking yard? i have found them on various tercels that had the 3A engines. even the sideways engines have them though they are located in a different spot. takes a 19mm wrench to get them off and sometimes they are very tight.
Nwtercel1
Post by Nwtercel1 »
Thanks everyone for the feedback I was able to order a new one and have it installed now
