3AC or 4AC
Jonymoto
3AC or 4AC
Post by Jonymoto »
This weekend I adjusted the valves on my 3AC engine. As I didn't have a new valve cover gasket, I borrowed one from a fully reconditioned engine that I bought earlier last year. It was advertised as a Tercel engine and it definitely looks like one. But the valve cover is different from my 3AC's cover, see attached photo. Note that one side of the cover is wavy. I suspect that this cover is from a 4AC engine. My question is could the whole engine be a 4AC not a 3AC? How do I tell without removing the cylinder head and measuring the bore diameter?
Jonymoto
Re: 3AC or 4AC
Post by Jonymoto »
The block is stamped 3A, maybe the cover is was a later version.
Re: 3AC or 4AC
it is possible it was a "crate engine" imported from Japan, than it might be a 3a with a different head. Or it could be a 4a as noted (not all of the 4a had the "wavy" valve cover either). if there are no external markings you can do a "displacement test" that determines displacement without having to pull the head off. you use a graduated cylinder, with the engine at TDC, valves closed spark plug off, carefully measure how much fluid (like oil, water, solvent, anything handy) will fill up the chamber to the top of the spark plug (it helps to tilt the engine over so the spark plug is the high point of the combustion chamber). than suck or blow it all out, and set the piston at bottom dead center, and do it again. from that you can determine the total displacement (multiply the difference in the two measures by 4) and you can determine the compression ratio (divide one by the other).
You want to do this fairly carefully, so it is accurate. But you do not need to pull the head to determine the displacement.
Re: 3AC or 4AC
Could be a 3a scv engine? they had a slightly different head and the one in my first Tercel was a JDM replacement 3a SCV and actually felt revvier than the normal 3a
Jonymoto
Re: 3AC or 4AC
Post by Jonymoto »
Matt - I did a search on the 3A SCV and it looks like you are right. But I can't find what the difference is between the 3A and 3A SCV apart from the head being different. Do you know? I take it it is still 1.5L and 52KW rating.
Re: 3AC or 4AC
No i'm not sure. The 3a scv engine was lower km by about 150,000 to my 3ac car that replaced it which probably made it seem a lot faster. I think the SCV was a later model with a Swirl Control Valve? whatever that was!
