I have found these on ebay and look like they might work on my front end of my '86 wagon (FWD) ;
SuperPro Polyurethane Front Sway Bar To Lower Control Arm Car Bush Kit SPF1064K http://www.ebay.com/itm/331509011691?_t ... EBIDX%3AIT
SuperPro Polyurethane Front Lower Control Arm Inner Car Bush Kit SPF1062K http://www.ebay.com/itm/331509011450?_t ... EBIDX%3AIT
SuperPro Polyurethane 21mm Front Sway Bar Mount To Chassis Bush Kit SPF0979-21K http://www.ebay.com/itm/251885409615?_t ... EBIDX%3AIT
I think they might work and save me from changing them out every 3 months! We have a lot of bad roads here in Costa Rica!
Good times!
Bruce
Polyurethane front suspension components??
- My tercel:: 1986
- 4wdEconoBox
Re: Polyurethane front suspension components??
I've had the first ones in my car for about 2 years and they've held up perfectly fine. Seems to make it handle a little better too
- My tercel:: 1986
OH thanks, I just started another post on this before I found your response! I'm going to try them!
Good times!
Bruce
Good times!
Bruce
- Jonymoto
A few years ago, I decided to replace all the rubber bushings on my 84 Tercel and I used Superpro throughout except the front Swaybar (they didn't have them for 21mm) and they are doing fine. I used Nolathane for the front sway bar. I've ordered the same for my 87 Tercel.
I also have the same bushing kit, and have no major complaints. Superpro has a good quality.
- helipilot77
- My tercel:: 1984 SR5 wagon
I just used the link above and ordered these. This is the last component I need to complete my front suspension rebuild.
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
