Intake sensor
JDNightFox
My tercel:: toyota
Intake sensor
Post by JDNightFox »
I don't know what this goes to but the wire broke off it, I'll figure out how to put it back on later today but what is this for
BaileySims
Re: Intake sensor
Post by BaileySims »
Coolant temp sensor?
WAGON MAFIA.
Blood, sweat and beers.
Re: Intake sensor
pry rubber out
get small female blade fitting and crimp it to wire
Re: Intake sensor
that is the temp sensor for the emissions control system, it measures the coolant outlet temp. The one for the temperature gauge is on the front of the head (next to the valve timing cover). likely it would run fine without it, but it is an easy fix as Xirdneh points out.
JDNightFox
My tercel:: toyota
Re: Intake sensor
Okay cool thanks guys
Re: Intake sensor
in the picture the other temp senor is showing that the wire to it is disconnected, it goes to the temp gauge on the dash.
Jonymoto
Re: Intake sensor
Post by Jonymoto »
My Tercel isn't even fitted with one of those sensors.
