I think there is an access panel. The lines are underneath the rear cargo area. Pull up the carpet that covers the spare tire. There should be a panel.
Replacing welded-on muffler despite unsolved gas smell
- helipilot77
- My tercel:: 1984 SR5 wagon
Re: Replacing welded-on muffler despite unsolved gas smell
. / TOYOTA
./_| |/|/ |]
./_| |/|/ |]
I removed the RR wheel and jacked up the car, thereby giving access. It IS cramped, but quite doable.stanrob wrote:Thank you Petros and Archinstl, I'll give it a go. Archinstl, how do I get at those rubber hoses?
If the vent line is leaking you will not see any wet spots but it will stink of fuel.
- My tercel:: Two 1985 Tercel SR5 4WD, Cal. emission controls, one now a parts car (good engine & transmission, still had full power at 310K), another, a low-rust project car, with 307k miles, from Petros
A quick update: the weather has begun closing in hard and my age is showing, slowing this project to less than turtle speed. I had already mentioned failed muffler and a hole in muffler feed pipe. That actually got dramatically worse as I drove home the last time. The entire exhaust system collapsed, including all but one of the welded supports. The exhaust is open right out from the engine pipe. Pretty impressive noise! You'd better believe I'll never go back to the exhaust shop that put that all together about 40 months back. The gas smell persists even weeks after dry-docking my beautiful companion. The rear wheel was stuck on, but I think I've got it loose now, aiming to reach up for the suspect hoses. I went with a connected friend to the local auction seeking a post-2000 Corolla, got beat on two bids, and expect to go back next week. If Petros brings a fixed-up T4wd, the Corolla is resellable or he can have it.
P.S. Somebody bid $3351.99 for that 83T4wd in Vermont and it still didn't meet cabinguyvt's reserve!
Another update, and confession, and apology: All along, I've insisted that what's leaking is not gasoline, but only vapor. Evidently I was wrong from the beginning. The evidence: After roughly three months of non-use, the gas indicator went down from 1/3 tank to the empty mark. Now when I try to start the engine, it doesn't fire at all. The smell is still in the passenger compartment, but substantially abated. My prior insistence was based on the absence of wet spots anywhere. Apparently that doesn't matter. Please accept my apology for dragging you all into a wild goose chase. Meanwhile, Petros DID bring a fixed-up T4D, bless his heart. Well, it needs a little more fixing, but it's time to be optimistic for a change.
