overheating woes
overheating woes
Post by xirdneh » Sun Aug 21, 2016 3:39 pm
my friends tercel has been overheating
he installed new radiator (still hot)
i came over and removed the thermostat and temp gage goes to halfway point and holds for a bit then climbs up till fan comes on, fan stops after a while but temp does not drop. (i expected engine to run cooler)
pulled all plugs to see if any were unusuall but all were brown and dry
no white smoke out of exhaust
there is a bit of dripping coming out of the bottom of waterpump
could the water pump cause this much trouble?
in the past i have had pumps that dripped but did not cause overheating
atoyta
My tercel:: 3 wagons now
Re: overheating woes
Post by atoyta » Sun Aug 21, 2016 5:49 pm
I found one that the impeller came loose of the shaft, wasn't turning. It made a funny "tink" sound as the shaft turned & nudged the impeller every so often. One in 30 years so it is not at all common.
Post by dlb » Sun Aug 21, 2016 7:00 pm
the coolant passages in the block might be covered in scale and sludge, which would prevent it from adequately transferring its heat to the coolant. if you have a water hammer-type tool, it's an easy thing to try.
Gottolovem
Post by Gottolovem » Sun Aug 21, 2016 9:53 pm
Sounds like the pump needs replacing anyhow!
Might just be what the doctor ordered :oldgeek:
Post by Petros » Mon Aug 22, 2016 12:14 pm
it is extremely rare that a leaky water pump would cause over heating. that just means the seal is going bad. if the shaft is wobbling it means the bearings are bad, which will make the seal leak, but it will still pump. Unless the wobble has whipped out the impeller, which is possible but very unlikely.
It is also very unlikely the impeller fell off, but it can happen.
As pointed out, if the seal is leaking, the water pump needs to be replaced. It will not be long before it completely blows out, just replace it now.
If you have a good radiator, t-stat and water pump, about the only other problem the cooling system might have is a weak lower radiator hose. It must be stiff enough to stay open when the engine is rev'ed so the suction of the coolant pump does not close it off.
Even a leaky head gasket will not cause it over heat if there is coolant in the system, it will only over heat after you loose enough coolant through a head gasket to overheat.
Also, double check the radiator cap, if it does not work properly it can also cause an overheat and coolant loss.
Post by xirdneh » Mon Aug 22, 2016 11:36 pm
removed waterpump today and there was almost nothing left of the impeller
the blades were gone
all that was left were pointed spokes
all was rotted away
put it all back together with good used pump and 3 new "o" rings (2 on bypass 1 at block) and all is well
this car is a mess, also replaced front axles, left control arm, tvsv, egr valve, donuts to support exhaust system (had rope and strapping tieing it up), plugged hole in cat conv where the small pipe was connected, rear hatch lifts (shock absorber like things). still need pass door window regulator fix & muffler
Post by Petros » Tue Aug 23, 2016 1:36 am
wow, must have had a corrosive mixture in the coolant. I wonder what else may have been corroded away.
one of the reasons to change the coolant out every 2-3 years.
Post by xirdneh » Thu Sep 08, 2016 2:32 pm
added picture to original post up there
