The car has always been cold blooded but now it's getting out of hand! This last weekend I did a full tune replacing carb and TVSV valve. The parts were taken from a car that runs like butter. After the tune it runs way better but the mid temp flooding problem remains
The newer carb works perfectly all diaphragms check out rebuilt last year and running smoothly on prior car same with TVSV one year old and still shiny.
I know my way around this car and have done all the work on it myself for years I'M STUMPED?
What are the symptoms if the solenoids are reversed?????
What would cause a motor to flood out that is NOT carb or vacuum related????????
Again the car starts up just fine at first but floods itself before its fully up to temp. If i'm able to get the car past the morning warm up cycle it runs fine for the rest of the day.
I should add that this car always run rich with poor mpg this is the third carb i've had on it always the same problem( it's not the carb itself some other component)
Paul
Remember when we left Virginia City and the car kept sputtering and almost died? (that is the symptom)
