FUEL FILTER Replacement
vcp
My tercel:: 1987 Tercel 4WD wagon
Post by vcp »
Gonna replace the fuel filter as part of another job viewtopic.php?f=4&t=11291 (starting a new thread so the subject will be searchable for others)
Did this before and it was pretty messy so figure I need to depressurize the system first. (Searched the FSM and damned if I can find anything on the fuel filter.)
Any tips on the best way to do this? Thanks!
Re: FUEL FILTER Replacement
Nothing fancy. I've just taken off both hoses, and put them on the new filter.
Use a Corolla filter from the mid 80's that uses the 4AC. Bigger filter but you need to swap the in and out.
95 Camry Wagon, 170k
97 4runner, 275k
vcp
Post by vcp »
No problem this time. Must be getting smarter ;-)
JackWagon
My tercel:: 1986 Toyota Tercel Wagon FWD
Post by JackWagon »
Would you mind posting the preferred 4AC fuel filter model number & brand?
Go to rock auto
1986 corolla
1.6L L4 SOHC
Then you want the fuel filter that looks like ours like the
PUROLATOR Part # F20265
Then you just reverse the in and out hoses
Brand is not so important. But wix makes a clear one that is nice
97 4runner, 275k
J Dumarais
My tercel:: Toyota Tercel 4WD Wagon '86 & Jose 87' Tercel 4WD Wagon
Post by J Dumarais »
Why reverse the in and out?
Because the Corolla filter is reversed.
97 4runner, 275k
