Front wheel bearing size
hi guys im new here. im trying to replace the front passenger wheel bearing on my 86 t4wd. I have removed the old bearing from the knuckle. the new bearing is a national 513002. here is the kicker i pressed it in and the outside race hid half of the c clip groove (clip install impossible). I pushed the bearing back out and compared it to the old outside race and sure enough the old race is not as wide. its 1.22 inches and the new national is 1.29 in. I cant see any part numbers on the old bearing or the spindle. When i took everything apart the spindle nut was hand tight after removing the cotter pin and the inner race and hub pulled free from the outer race without any tools. it appears that PO put a new half shaft in. it looks shiny and new. i am assuming the bearing failed because the halfshaft is designed for the 1.29 wide bearing and with the 1.22 bearing in insufficient clamping load of the inner races was achieved causing premature failure. All the documentation i see for a 512002 bearing shows it should be 1.29 wide. The only doc i could find with the 513002 bearing showing a 1.22 width was a timken bearing guide. a quick google shows summitracing carrying a timken 513002 spec of 1.29 width so im totally lost. What is going on here? do i have the wrong spindle on my car? when i was pulling the old bearing my inner seal looked nothing like the new seal and back up ring. it was metal on the outside edge and more robust then the new outside 2 peice seal i have and the one shown in the youtube video. Maybe that seal is a clue but i see no part numbers on it either.
Re: Front wheel bearing size wtf
welcome, mtc1984.
i don't remember this topic ever coming up here before. i think the best thing will be if someone has a spare front wheel bearing kicking around that they can measure for you. i don't have one but someone else should. hang tight.
if you found the clip groove was half hidden by the 1.29" wide race, making clip installation impossible, i would guess that the 1.22" is the correct size. the bear failure could be due to the CV axle nut simply not being done up tight enough, allowing the axle to slide back and forth inside the bearing.
here are some pics
front wheel bearings
KOYO DAC357233AW or NSK 35BWD06A or KOYO DAC3577336W
or Raybestos 66-713002 (13033 LA), BCA Federal Mogul 513002 (30.00 ship incl 6/14)
1.376” ID x 2.835” OD x 1.218 THK (35mm x 72mm x 31mm?)
thats my measurments using dial caliper
video http://www.youtube.com/watch?v=uMiktl5qzCw
1.2178inches is 30.93212mm not 33mm
none of the part numbers yield any clues via google fed mogal crosses with timken and national 513002 which is too wide
713002 used in the video also crosses with 513002 which is too wide
i changed it (edited)
did you look at rockauto listings for bearing numbers
they usually list quite a few
the ones i listed are ones i have removed and or used
are you sure that hub is correct for tercel
looking at your picture something seems off
will have to go out and look at one
rockauto has 4 front wheel bearings
raybestos 713002 no dim shown
beck arnley Inner Diameter 1.378
Outer Diameter 2.8346
Width 1.2992
national (which i have and know is too wide)
Bore 1.378"
Outer Diameter 2.8346"
Width 1.2992"
and timken wich rock auto says is
Bore (in) 1.378
Inner Ring (in) 1.299
Outer Dia (in) 2.835
Width (in) 1.299
Width 1.2992
Bore 1.378"
Width 1.2992"
Bore (in) 1.378
Width (in) 1.299
[quote="xirdneh"]front wheel bearings
what exact bearing out of those did you physical measure 1.218inches?
i just measured a hub from 4x4 tercel
looking at the side the bearing is installed into
approximate measurements using dial caliper
overall thickness is abt 2.235"
distance from top down to bearing seat (ledge) is about 1.793"
distance from top down to bottom of snap ring seat ( beveled ledge) is abt .603"
distance from top down to top seat for snap ring (ledge) is .443"
the snap ring is .096 thick
so 1.793 minus .096 + .443 = 1.253 space for bearing
a 1.29 thick bearing is not going in there
i did some bearing replacements last year
i have 2 used (original equip) bearing race's marked KOYO DAC3577336W that are 1.219 thick
and 2 others (used) that i cannot see numbers that are 1.219 thick
the mfr's must have changed the size of the bearing
thats not good for us
i found the paperwork for the bearing i installed june 2014
it was a national 513002 from rockauto
i am wondering about that 1.299" measurement shown on rockauto for 513002
that could be the distance measured at outside to outside of the inner races of an assembled bearing
the outer race could be less than that
i picked up a national 513002 from advance auto today. here it is next to the advance auto national i picked up earlier.
the new bearing appears correct. low and behold the correct bearing is made in the usa
