Hi everyone,
turns out the great junkyard find radio and trim doesn't fit my 84 SR5... If you have one for sale(any color) PM me.
Also Broke one of the nipples on my HIC the other day after CARB install, looking for one of them bad boys too.
Thanks!
WTB RADIO TRIM / HIC VALVE
Re: WTB RADIO TRIM / HIC VALVE
exactly what part of the radio trim (center console cover?) are you looking for? have a pic you could post of what you are looking for?
I think I have one in a deep brown color that is cracked, which could be fixed with epoxy or something similar. You are welcome to it for the cost of mailing.
- C130
- My tercel:: 1984 SR5 280K Lift and 195 75 14.
Thanks Petros, if it's cracked it's probably what I'm looking for. It is the plastic radio surround between the ashtray and the trans tunnel. The one depicted is the larger one from the DLX. It's up for grabs if anyone would like it.
I have HIC valves
I may have one for you, in that color. I have to remember to look for it.
I replaced a beat up one on a fixer that I sold a long time ago, I just happened to find a good one at the local PicknPull. I saved the old one because I thought it might be better than nothing if I need one in the future. I have had several T4wd where for some reason the idiot previous owner takes it out and looses it (installing or removing a radio or something). But I do not recall if I have used it on another car or not. so I need to look for it.
- C130
Much appreciated Petros. I'm holding off on the stereo install until I can source the parts. For now I've got an 80's era boom box strapped in the passenger seat belt powered by a small inverter running off the cigarette lighter. Pretty rad.
Xirdneh I'll PM you. Thanks!
- C130
HIC valve en route. Thanks XIRDNEH. Still looking for the trim.
Got a medium brown radio surround if you still need it. PM me
2005 Toyota Sienna, work van
85 Toyota MR2 (Blu)
83 Mazda RX-7 Mariah Widebody
85 Toyota MR2 (Blu)
- C130
Already got it synth! Thanks
