I'm not entirely sure, I gave it a fresh oil change prior to letting someone else use it for about 2 weeks. It blew the rod when they were chugging up Hill to their home.
I did a rear main seal and rear cam plug before I started driving it. I didn't see any oil loss after that. It must've been prior damage from the rear main seal leak I presume. My only hint is the one time the oil light flickered when coming down from high rpm to idle (after dropping idle).
Looking at a 4wd manual tercel with a blown tranny
- My tercel:: 1983 Toyota Tercel SR5 Wagon
Re: Looking at a 4wd manual tercel with a blown tranny
that is what I noticed it on my truck when I first got it, after warm up the oil light flickered on and off at idle. I put an oil pressure gauge on it to see what was going on. when cold it went up to 40 psf, ran about 18-20 psi, but at idle dropped down to 5-7 psi when the light would flicker on. I put two cans of STP in it and kept driving it, hoping for the best. one hot summer day it started a mild knock, oil pressure slowly dropped 18 PSI, 16, 12, 10 as I drove it, and than "bang"!. I felt engine parts bouncing off the floor boards from under the car, and I saw them bouncing on the road behind me in a blue cloud. I felt like a race car driver who blew an engine, the cars behind be were swerving to avoid the engine parts bouncing up off the road surface.
when I first discovered the low oil pressure, I had to either risk driving it and trashing the engine, or take the time to rebuild it. I was in the middle of trying to get a house built, and working full time. I bought it to haul building materials around for the house building, and had all my "spare" time full with working, building a house, and with a toddler at home. My thought process was, take the time to rebuild the engine now, or risk trashing it so I had to replace it. With those "miracle" oil additives I thought I might "avoid costly repairs" (like it says on the bottle). I got to replace and rebuild it anyway. I found a long block engine at a wrecking yard for only $100 (a rebuild-able core, not a good engine), so it was not that costly a gamble. More of a inconvenience.
