Read Factory Service Manual(FSM)
Looking for Ignition Vacuum Advance
Moderators: GTSSportCoupe, ARCHINSTL, Mattel
Postby jebudallaha » Fri Jul 30, 2010 11:22 am
Hey,
Anyone have an old functioning vacuum advance kicking around I could sure use it. I'm looking for the dual one that you find on the M/T (the car it's going on is an '83) with the two ports and not the three that you see on the A/T. If you have one let me know the price. Thanks.
-Aaron
jebudallaha
My tercel:: 1983 SR5 4X4
Re: Looking for Ignition Vacuum Advance
Postby takza » Sat Jul 31, 2010 12:30 am
2 things you MIGHT be able to do: run with no vac advance...I still get good mpg...idle might suffer a little....timing is advanced some. Remove the "can" and grind around the outside crimp...take it apart and repair the diaphragm.
When I looked to replace them....think you needed to buy a whole new or rebuilt dist.
"The future ain't what it used to be. We made too many wrong mistakes. You've got to be very careful if you don't know where you're going, because you might not get there." Yogi Berra
Postby garyfish » Sat Jul 31, 2010 11:42 am
takza wrote:When I looked to replace them....think you needed to buy a whole new or rebuilt dist.
I helped a friend of mine replace the vac advance on his dizzy a few months ago. He bought an aftermarket vac advance from Napa for about $62 and the only kind available had 3 vac ports.
I did mine about a year ago and got the part from Rock Auto for about $56 + shipping... but I was buying a whole bunch of other stuff from them so the shipping was no big deal. Again, mine had the 3 vac ports.
You can just plug the extra vac port you don't need, I think.
Hope this helps.
1985 Tercel SR5 4WD Wagon, 6 speed manual, 244,000 miles
garyfish
My tercel:: 1985 Tercel SR5, stock
Postby xirdneh » Sun Aug 01, 2010 1:55 pm
garyfish wrote:
takza wrote:quote]
Hope this helps.
the top inside port with the very small hole (pin size) can be plugged
its for the high altitude stuff
My tercel:: 83 tercel 4x4 wagon w/reringed engine, 86 tercel 4x4 wagon w/salvaged engine, 83 tercel 4x4 wagon w/salvaged engine and '86 tranny
Postby takza » Mon Aug 02, 2010 1:37 am
If you close off a port on an extra diaphram...you might keep the advance from working right?
Postby ARCHINSTL » Mon Aug 02, 2010 3:19 am
My third port (the one with the constriction) is plugged, as STL is not very high up in the mountains, so no need for the HAC valve...
No probs.
Oh, do not ask, 'What is it?' Let us go and make our visit.
Now and then we had a hope that, if we lived and were good, God would permit us to be pirates.
My tercel:: I am aka "Mordechai" on Toyota Nation. My T4WD is a 1986 SR5 attualmente con Weber/also owned possibly the first T4WD in STL in late '82
Postby Petros » Mon Aug 02, 2010 5:07 pm
I usually check the vac advances on all the dist I find on every 3a or 4a equipped engine at the local pull-a-part. Most of them are shot, it is rare to find a good one. And it usually does not last very much longer anyway.
I am considering grinding off the swagged lip and see if I can not make a new diaframe, and find a way to make the vac advance serviceable with a removable clamp around the pie tin. It would save a lot of money in the long run, and solve the problem for all future vac advance issues.
'85 MR2 (current project)
'84 Tercel 4wd (daily driver, with mods)
'92 Mazda MPV 4wd (wifes daily driver)
'86 CRX (daughter's daily driver)
Return to Tercel 4WD Parts: New and Used
Who is online
Users browsing this forum: 4wdchico, Petros and 0 guests
Powered by phpBB © 2000, 2002, 2005, 2007 phpBB Group
