Dissection of the failed distributor vacuum advance unit
c_j
My tercel:: T4WD#4: '86 SR5 6-speed, original Barto lift & steel bumpers & winch, also 95Amp alternator
Post by c_j »
Starting to pry the lip on the upper chamber:
using a Proto #1204E 1/8" combination wrench
Starting to pry a little more:
using a piece of bent sheet metal with a small hacksaw gouge
The tool:
The intermediate pry tool was a flat screwdriver blade, and then the mini vise-grips which finished the job:
Removing the upper chamber (showing diaphragm adhesion):
Upper chamber removed:
Ruptured upper diaphragm:
Prying the lower chamber:
The tools used here were a blunt scratch awl, a flat screwdriver, and a pair of pliers.
Lower chamber removed:
That wood you are seeing is a little jig I made to hold the vacuum advance firmly (not intended to resemble your pet or any trademark character):
Made by drilling 4 small holes to make slots for the ports, and then using a 1&3/4" hole saw, then handsawing the thing in half.
Die grinding the rivet which (I thought) held the assembly together (do not do this):
By fluke I discovered that all you do is push and turn (like on a radiator cap):
A better view of the jig:
Lower diaphragm removed:
c_j
Re: Dissection of the failed distributor vacuum advance unit
Post by c_j »
There is a leak along a crack in the diaphragm, but not a total failure yet:
All the parts in order of assembly:
Close up of parts - side 1:
Close up of parts - side 2:
