Hey all,
I got to some structural repair on the front yesterday, renewed the distributor o ring this evening. I likely backed the timing off a small amount as well, set at 10 deg before.
I've got some tube steel I'm going to rebuild the rear control arm mounts with and prepped it some last Thursday. I'll provide pics on that work and semi detail my approach. Then new springs and struts/shocks all around (and a couple of tie rod ends) and I'll be hopefully set for a bit.
"apparent leaking clearly seen"
Here is the bottom cover Tom
Distributor o ring
Distributor o ring
Re: Distributor o ring
Chris -
Jealous.
I was gonna post the Mr. Green emoticon, thinking it meant "envious" or "jealous;" it does not.
Tom
Jealous.
Tom
