Heat and light - lots of both
- My tercel:: 85 SR5 4WD Wagon
Picture is at 10pm, sunset had just started. Love this time of year. Three months ago the sun was above the horizon for about four hours... Can't see in the phone picture, but Denali is right there, 100 air miles away and 20,320' above sea level. It's a beautiful day in the neighborhood.
Re: Heat and light - lots of both
what was the cooling system flush tool you used? i bought one from the US a year or two ago, basically a water hammer that you connect to tap water and compressed air. it did a great job on the last tercel i had, which would only put out tepid air, at best.
Oh yes, I would like to know what you used as well. Include a picture if you can.
It uses water and air. Back flush first and then alternated a couple of times. Only got wet once.
It creates a 'water hammer' sort of action... Using an air chuck you just hit it with air now and again to give all that crap in there a little jolt and shake it free. Need to make a couple of them, one larger so I can do the engine block too.You do not have the required permissions to view the files attached to this post.
