Hi guys,
I replaced my fuel tank last night.
Bought a brand new TO1A.
Now, the sending unit (For float level) is fine, but the pick up line is weak. I had to weld new tubes since the 3 tubes from the pick up hanger were rusted out.
I'm looking for a replacement unit, but can't find one that actually 'Fit' the 4WD tercel.
What do you guys use to replace the rusted unit?
Here's a picture of the only one I see to find available, do you buy this one to fit in the 4WD?
Let me know...
Thanks for your help!
Aftermarket Fuel Tank Pick up hanger?
Re: Aftermarket Fuel Tank Pick up hanger?
where are you at? You might have to find a good used one. The rwd corolla and celica from the same years might have the same part, or something really close to it.
I'm in Montreal.
I would really like a brand new unit just in case.
I don't see the part available from the supplier I use so far, not even on ebay...
Did you check with Toyota?
I got one a couple of years ago, should still be available.
I have one that I just removed from my 84 tercel 4x4 sr5 (I'm instaling a 4age 20v B/T fuel injected pump in the tank) the one I have is in good shape I live in montana rust is'nt a problem 30.00$ plus freight Larry:
