1986 toyota tercel,4age motor - $3000 Portland, Oregon
GLet71
Post by GLet71 »
Sorry folks, front wheel drive, but what a gem!
https://portland.craigslist.org/clk/cto/6116466310.html
Currently:
Formerly:
Re: 1986 toyota tercel,4age motor - $3000 Portland, Oregon
That is worth buying for the engine set up, it would be a shame to part that one out, but to get the whole 4age engine, exhaust and fuel system set up, as well as flywheel, alone to install into a T4wd, this is a bargain. It would be a bolt up 4age engine swap, ready to go.
It would be nice if this 2wd chassis could be made 4wd, but no such luck. Take the engine installation and go with it. There must be a custom header or exhaust system that you would need, plus the efi installation, and a lot of other details that has to be fabricated, altered or made to work. The MR2 seats would be a nice touch as well.
GLet71
Post by GLet71 »
I was thinking the same as I was posting it here. Wish I had the $$$ to follow through on that.
Currently:
Formerly:
I have about that much into a 4age build, and necessary parts, and I am not even done yet getting everything I need for it. a custom header/exhaust alone will cost close to $1000, unless you can do all the welding and bending of tube yourself. even than, it will not be cheap.
Post by irowiki »
That looks like Gottoyota's car.
It IS!
viewtopic.php?f=6&t=9536&p=74245#p74242
