Toyota tercel 86 (parts) - $400 Bozeman, Montana
GLet71
My tercel:: '87 6-spd SR5 4wd Wagon
Post by GLet71 »
Currently:
Formerly:
Re: Toyota tercel 86 (parts) - $400 Bozeman, Montana
GLet71 wrote:A bit of a fixer upper...https://bozeman.craigslist.org/cto/6100110890.html
Lordie, but - a cool color - glad it ain't near moi - and, if I had a garage!
Oh well, if wishes were horses, etc. ...
LOSTFISH
My tercel:: BLUE 87
Post by LOSTFISH »
is he referring to the smashed fender and bent wheel as a 50 dollar fix?
BaileySims
Post by BaileySims »
Maybe he forgot to add an extra zero?
WAGON MAFIA.
Blood, sweat and beers.
maybe $50 for picknpull parts, but a strut insert is about $60 by itself. there is likely more damaged than the fender and strut, but that is a minimum. it can be fixed, but the price is a bit high for the amount of damage it has.
larry mcgrath
Post by larry mcgrath »
When you find a car I have a VERY GOOD engine, that I would sell you, pretty cheap-- also 2 axles with about 1000 miles on them and a clutch and pressure with 1000 miles on them. I live in Butte which is close. Larry
Rickety Rhino
Post by Rickety Rhino »
Larry, do you still have those two axles? I need a left axle, and will be driving through Butte next Fri or Sat (July 7th or 8th) on my way from Colorado to Canada, and I could stop by. Did they work well when they were last on the car?
Thanks,
Steve Monk (303) 444-2920
Smokey The Brake - 1984 4WD, 230K
