Not a T2/4WD Wagon, but - WOW!
http://www.ebay.com/itm/1988-Toyota-Ter ... 2344619065
'88 EZ with less than 26K miles! Unbelievably clean, and in Vancouver, WA! 4 speed, no AC - wonder if used as a tow-behind?
currently at $2000, with reserve not met.
- splatterdog
Re: Not a T2/4WD Wagon, but - WOW!
Wow is right. That car could last longer than many other brand new cars purchased today. Provided parts are still available for another 30 years...
- Mad_Marx
- My tercel:: 1986DLX (K.I.A. by a Texting Driver, currently being uses as a parts car) 1986 SR5 AC, Cruise, Sunroof a.k.a. TERC II Electric Boogaloo (restoration in progress). 1984 SR5
Gimmie!!!
if you manage to get it and drive it another 30 years I can see your great grand children asking the old man, "gee, people used to actually drive cars like that once?"
"Reserve not met" at US $4,450.00 ! For a sedan!
- My tercel:: 1983 SR5 stock
That this is the most beautiful second generation and I hate then with a passion.
It has been relisted: http://www.ebay.com/itm/1988-Toyota-Ter ... 87?vxp=mtr
- My tercel:: 1988 tercel ez
this ez ended up in nyc, where i just bought with 74k miles
- LowBuckCanuck
Reminds me of this '86 with 75000km:
https://www.kijiji.ca/v-cars-trucks/st- ... nFlag=true
Then there's this '85 with 90000km:
https://www.kijiji.ca/v-cars-trucks/sas ... nFlag=true
Why did people drive the hell out of the 4wd models, but leave these ones to sit?
i originally found and fell in love with an ‘83 fwd 5-door hatch in pale yellow, but the rust was too much and it was 100 miles away from home.
also found this one:
https://nwct.craigslist.org/snw/d/inner ... 60463.html
that one in the add is a great price, it is also the 4wd SR5 model. well worth owning, but realize cars this old, even with relatively low miles, will need to have a lot of parts to replace and keep after. they are reliable, but these cars are approaching 35 years old, things wear out. I have about 400,000 miles on my daily driver, and almost all of the moving parts have been replace twice (bearings, seals, tie rod ends, engine, clutch, trans, mounts, etc), some 4 times (it is on it's forth clutch). so you have to either be handy and replace a lot of the parts yourself, or be prepared to spend a lot replacing old parts that wear out.
